Old 11-17-2013, 04:57 AM   #1 (permalink)
ElPants21
The manic mechanic
Hondo - '03 Hyundai accent gl
90 day: 33.81 mpg (US)
OEM-looking Kill switch/secondary starter
Hey guys, been a while since my last post. Been working on wiring in a 3 position switch to EOC and start the engine again without needing to touch the key. There was a lot of head scratching over what to do for the kill switch part but thanks to another forum just for Hyundais, I learned Hyundai offers free shop manuals as printable pdfs on there site. WOOT! http://www.hmaservice.com/ you need to register, but it's free. Firstly, I wanted to keep it looking as clean and stock as possible. I decided to use some of the unused switch covers
I started by removing off the center council panel and chose a cover to hack up
https://lh6.googleusercontent.com/-m...114_004003.jpg
broke some stuff out of one of the covers and drilled a hole for the switch
https://lh6.googleusercontent.com/-1...114_010215.jpg
https://lh4.googleusercontent.com/-p...114_011536.jpg
https://lh5.googleusercontent.com/-S...114_011524.jpg
Then to try and make it look really slick, i found the font hyundai uses and made a stencil to paint on the switch functions
https://lh6.googleusercontent.com/-N...116_220631.jpg
https://lh3.googleusercontent.com/-q...116_222534.jpg
This guy is the engine control relay where all the fuel injectors ground. Took me a while, but i found it through an interactive electrical pdf that gives the numbers and colors of wires and lets you zoom in on specific wire harnesses with everything numbered. Anyone with a Hyundai should take note. Very comprehensive.
https://lh5.googleusercontent.com/-K...117_005742.jpg
Dont forget your heat shrink tubing
https://lh4.googleusercontent.com/-2...117_012821.jpg
Solder it all up
https://lh4.googleusercontent.com/-c...255B1%255D.jpg
That's all the pics for now. Ill finish up the assembly in the moring, but the electrical bits work perfectly on the kill switch and on the starter side as well. Bonus points for coolness?
The Following User Says Thank You to ElPants21 For This Useful Post:
TexasCotton (11-17-2013)
