The thing about Honda transmissions is most of the parts are swapable so even is we had the case markings I could not tell you for certain what you have.
Those speeds with stock tire size sound normal so I'd say you do not have the (Canadian D series) SI transmission. So you most likely have the original DX box. And compaired to the DX your CX is starting off in second gear.
