yeah I'm running an innovate gauge that reads like 34 when the engine is off lol... you are correct iI'm running a chipped p06. and yes at any push of the throttle I have the tune adding fuel so it runs the best. as far as vtec goes, I may have misunderstood you, but you DON'T want vtec (all 16 valves, basically a regular non vtec engine at this point) if you want to best mpg. the tune is way more capable of a safe lean burn with the swirl effect that happens when only running 1 intake valve per cylinder (12 valve mode)
