Originally Posted by Fat Charlie
Constantly being on any sort of trigger isn't safe.
If you're that ready to slam on the brakes, you probably shouldn't be on the gas.
What makes you think that it is necessary to be "constantly on the trigger"? Using the left to brake with doesn't require holding it above the brake pedal all the time.
There is a distinct asymmetry in information here. If you never use your left foot to brake with, how can you be qualified to comment on it? As I opened with, I use either foot on the brake pedal as is appropriate to the situation. I do know what it is like to drive using either method.
Obviously some people don't like having their received wisdom questioned.
