Old 11-18-2013, 04:32 PM   #9 (permalink)
bikenfool
subey - '99 Subaru Impreza Outback Sport
rav4 - '07 Toyota Rav4
Peak engine efficiency isn't the same as best cruising fuel economy.
Peak efficiency on a BSFC map shows at what load & RPM your engine makes the most power/torque per unit of fuel burned. It's usually when making a lot of power, which is why it's applicable to accelerating and using the pulse & glide technique.
But it's not applicable when cruising in top gear because your power requirement then is a small fraction of power needed for accelerating (or climbing).
So you have to operate the engine outside of the "ideal" BSFC zone.
I get all that. It still doesn't explain DWL. I'm not trying to be annoying, just trying to understand the fundamentals.
