Old 11-19-2013, 02:42 PM   #1 (permalink)
whatmaycome14
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
Question I'm not sure what to make of this exactly... what do you guys think?
Rear Wheel Skirts A-B-A Test= mixed results.
So I'll put all the data here and let you guys take a look. I think I'm going to need to test a different day, but here it is:
It's a windy day in Richmond. 14-15mph winds traveling in the SSE direction. The ambient temp was holding at 50 degrees. I was on my usual test area which travels in a relative east-west direction. This leading to half my run being relatively "with" the wind and half "against." I also decided to test at both 60mph AND 70mph (was that a mistake?). The first readings are going from west to east, after the '/' from east to west.
Without rear skirts:
A1 (70mph)- 39.4mpg/38.5mpg [38.95AVG]
A2 (70mph)- 41.1mpg/39.1mpg [40.1AVG]
A3 (60mph)- 47.4mpg/46.0mpg [46.7AVG]
A4 (60mph)- 47.2mpg/46.1mpg [46.65AVG]
WITH rear skirts:
B1 (70mph)- 42.0/36.6 [39.75AVG]
B2 (70mph)- 42.9/37.5 [40.2AVG]
B3 (60mph)- 49.2/43.2 [46.2AVG]
B4 (60mph)- 49.6/43.4 [46.5AVG]
A1 (70mph)- 40.5/39.2 [39.85AVG]
A2 (70mph)- 40.8/38.9 [39.85AVG]
A3 (60mph)- 47.5/46.3 [46.9AVG]
Ok, after crunching numbers:
Total averages indicate that the rear wheel skirts have a -0.7% affect on FE.
However, I decided to compare runs "with" and "against" the wind individually and I came up with this:
With the wind: 4.9% INCREASE in FE
Against the wind: 5.3% DECREASE in FE
It would appear that as long as I don't have a cross wind hitting against my general travel direction then the skirts actually help, but where I'm confused is that if I DO have wind hitting me then it's hurting... I'm not happy.
