Old 07-01-2008, 01:05 PM   #67 (permalink)
MazdaMatt
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
because mine is not a cold maximum, i belive. If i set mine to 51, they'd be mid-high 50's on the highway and my sidewalls would have very little tolerance to shocking forces such as skidding sideways through a ditch. You are DEFINATELY NOT at the same level of safety as if you inflated to 40psi, though.
Do some searching for racing research for a chart of psi vs. grip. You'll see a major decline in grip after the "peak" level. If you live in a little boon-town and you never see any risky driving, sure, use the maximum rating. If you ever use highways near a city, I wouldn't risk it.
