Talk me through an EV! I'm tempted to build, but no real knowledge!
Right,
I have a hairbrained idea that building an EV version of a car could be a fun way to get a cheap commuter- that and a decent way to use some of the scrap and guff over at my unit.
I currently have a 64 mile commute each day- taking upto 1.5hrs each way, with no option to charge at work (although I could ask nicely!)
Charging would likely be at home overnight off my domestic supply
As I understand it, I need the following
1. Vehicle to be converted (likely RWD for ease of connecting to gearbox/bigger motor/skidz!)
2. Electric Motor
3. Potentiometer
4. Batteries
5. Controller
6. Charging system
7. Regen braking setup
So I need you folks to advise me on the following points
Electric Motor
What size do I need? 70 mile range at 50+mph
I understand that its amps drawn that's the key to matching output/heat/range?
Batteries
What type?
How many Volts?
How to connect and balance?
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
