Originally Posted by JRMichler
Back when I drove "normal", I would maintain 55 MPH uphill and down. That resulted in WOT throttle uphill and throttle closed downhill. When I learned DWL, and after practice, I still average 55 MPH. My speed now drops to 50 MPH uphill and reaches 60 MPH downhill. My manifold pressure (MAP on the Scangauge) mostly stays between 7 and 10 PSI. The secret to DWL is keeping MAP within the smallest practical range.
Result is that I gained a full 10% MPG while driving at exactly the same average speed.
What throttle position do you use on the hills now? What is it on the flats? Did you change any other driving behaviors at the same time? WOT is usually enrichened to get maximum power.
