Thanks for the comments guys. Working on the code now. Lot of this is gonna be trial and error as the finer points of how the pressure regulator valves are applied is not well documented. Nor is even if the valves run at 5v or 12v. So I'm starting at 5v. More updates soon.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
