Originally Posted by kach22i
I think the A-pillar bottom end is usually welded shut, perhaps a small weep or two if not filled with structural foam.
Would not be much of a fire wall if not sealed off anyway.
Cutting a hole anywhere near an A-pillar just doesn't seem wise. However, if you can get yourself into a junkyard to see a stripped down wrecked chassis and do an investigative autopsy on it, I would be interested in seeing the results/photos.
Supposing it is structurally feasible, where where it would be more beneficial to place the hot air outlet?
I mean fore/aft windshield header, roof mid section or backlight header
sideways roof center or roof edges
