Old 11-21-2013, 03:46 AM   #5 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Babette - '01 Renault Clio 172 Exclusive
90 day: 31.17 mpg (US)
Derv Olop - '96 VW Polo CL
90 day: 38.61 mpg (US)
The Miserly Missile - '01 Skoda Octavia Tdi Ambiente
Team m8
90 day: 48.67 mpg (US)
Puggit - '97 Peugeot 306 Dturbo
90 day: 42.8 mpg (US)
Alfalfa - '02 Alfa Romeo 156 1.8 T Spark
90 day: 27.31 mpg (US)
316 - '87 BMW 316
90 day: 31.02 mpg (US)
Vectra - '01 Vauxhall Vectra SRi
90 day: 32.14 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
Howdi Hay two - '01 Audi A2
90 day: 49.96 mpg (US)
Originally Posted by Ryland View Post
First off, to go 130 miles per day, you are going to need a huge battery pack, say 300 amp hours at 144v if you can keep your electrical draw down to 300 watt hours per mile and my figure there gives you a small buffer so you don't over discharge your pack and destroy it right away.
Anyway, you'll need to go with lithium batteries and just the battery pack is going to cost you at least $15,000 and weigh 1,000 pounds, if you want a "cheap" battery pack that will give you that range, you'll have a lead acid pack that weighs no less then 4,600 pounds, at that point you'll for sure need a truck frame, trucks out there tend to get 500-600 watt hours per mile... so double the size of the pack and suddenly your truck isn't big enough.
You have three options that I see, take out a loan to build your EV, move closer to your job, convince your workplace to let you charge at work or find a car that burns fuel that gets good mileage.
Hi, thanks for the response!
My commute is only 64 miles total, so I'd only need 70 miles range. Hopefully that'd make the battery pack smaller and more affordable?
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Merc s124 300TD
