Originally Posted by RedDevil
I did rent a Kia Shuma to tour the Azores island of Flores. The car was mediocre, to put it nicely. Nearly left me stranded because it could not climb a hill in reverse. Had to roll it down an ever steeper grading road to a rocky beach to find a turning point; finally turned it around in a ditchlike alley, covering the inside with mud in the process by a spinning wheel (we had the windows open... bad mistake!)
It sounds quite odd to me that you've experienced problems with a Kia. At least the ones I've seen in Brazil and Uruguay were not so bad altough often the owners abused them a little. Well, maybe the ones I've seen didn't have that problem with hills due to a lower differential ratio which is usual back here...
