Old 11-22-2013, 02:50 PM   #116 (permalink)
justme1969
justme1969's Avatar
quite rite!
Originally Posted by elhigh View Post
I'd be curious to see what kind of mileage you get, cruising at 80. The generalisation is that we're out for maximum range; that drops off rapidly when you keep the speed up.
I might touch 70 or so on my commute home, but that's on a downhill and feathering the throttle to keep out of regen. It would also be an interesting math question to see where the dollars fall: if time is money, is speed economical? At how many dollars per hour does more speed equal a savings?
I would need more/better instrumentation to record instant and average speeds and log those against fuel economy to be able to answer those.
If im running late always a morning issue due to traffic and single dad life issues. my mileage at 75 is dropped from 37avg. to a 31 0r 32 so speed has high cost. Ive still not procured the next larger diameter drive tire yet because at times I get clutch slippage during hard first gear pull outs. but think it would make a good difference at 75.
