Because when the engine starts by the IMA motor, there is some energy used from your 144v battery. There is also a small amount of fuel used to help start. When you bump start, there is only kinetic energy used. When doing my commute I can bump start 30-40 times. If every time I restart I do it with the IMA motor, it will be significantly less efficient. Bump starting is the reason why I drive stick.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
