Old 11-24-2013, 12:45 PM   #5 (permalink)
jamesqf
Originally Posted by jeff88 View Post
In reverse the hybrid only uses the battery/motor, so it can't have heavy loads in reverse, something you need to do to get the boat in the water.
Maybe a quibble, but why would you have heavy loads getting a boat into the water? Most boat ramps I've seen slope down enough so that you can pretty much just coast in.
And for the OP, for your high-elevation winter commute, keep in mind that having 4WD doesn't do anything to help with braking. Unless you'll be driving through snow deep enough that you need the extra clearance, a 2WD with chains will do just fine. I drive over 8500 ft Sierra passes in winter snow, in my 1st gen Honda Insight. No problems unless the snow is deeper than the belly pan.
The Following User Says Thank You to jamesqf For This Useful Post:
elhigh (11-26-2013)
