I have a z1 in a crx with an HF trans they do bolt right up for those who asked
Where did you get your obd0-1harness spend the money boomslang made one for me call them and tell them your putting the vx in they will send you the right wires to solder up have not had a problem with that.
Let's face it the z1 gets good milage but is fussy mine bucks etc like everyone else I've gotten 47mpg doing 75 from Chicago to florida, none less then 41 but not better then 50 driving like grandma. Been a yr since swap and 18k plus miles. My plugs constantly look like their fowled out only thing I'm missing is the cat.
Know a guy with a 100%stock vx same bucking hesitate problem solved with a p28 and a 4 wire o2 with p07 map no more lean burn. Even master Honda techs can't figure them out. On the dyno when the bucking hesitation came on is when lean burn was kicking in
