I've heard that one pretty sure mine is a08... I've just come to the conclusion you can have everything right on these and still get that stumble...I know a shop by me that tried every thing that's when they got rid of lean burn... I believe its in the ecu some just work better then others... Let's see I could run a cat get the ao9 o2 pretty sure it would still stumble and I'm out another 500 plus... Its a gamble with the o2 how do you order it telling them I need a ngk-ntk ao9 5 wire. Had the right numbers they don't know Thiers an ao8 and an ao9 only way to tell is its on the sensor it self not on the box
