Euromodder, I agree with most of what you're saying, but most of what you're saying is about P&G, not DWL which is what I question. Hills seem like P&G enhancement. Pulse on the climb, glide on the descent.
DWL implies constant load on the descent, in other words using the engine to increase speed. It's obvious gliding is best.
Originally Posted by euromodder
But you lose efficiency whenever you go uphill or downhill.
Uphill, a CC or the driver simply pours on fuel to keep the speed up.
I know you'd be using more fuel, but going uphill & keeping the speed up would usually be more efficient. When you're loafing along on flat ground your below the optimum region on a BSFC map. Higher load would bring you up and be more efficient.
You trade fuel for potential energy : your car's weight @ height.
The engine load increases, and so does your engine's efficiency.
High load and low rpm is where it gets its BSFC after all ...
Even if it uses more fuel/mile, it's producing the horses required to get up there more efficiently.
That sounds like a pulse in the climb, not DWL, they are opposing techniques.
Try DWL instead of CC for a few tanks.
It will give you improved MPG
I've been playing with it, but I don't typically use CC locally anyway.
