Originally Posted by vlad
I can call this experiment as failed. May be you need special carbon may be something else but at this point I call it FAILED.
I researched adsorption carbon a bit more, you do need special carbon from special sources processed in a special way, and the benefit does not seem linear with psi. Still a lot of vehicles moving in that direction, and some tanks in production.
