Old 11-26-2013, 11:22 PM   #1 (permalink)
100MPGPLUS
2005 Tahoe 170,000 Miles and getting 28 MPG
2005 Chevrolet Tahoe with 170,000 miles with 5.3 Liter Engine
Following Technology is installed and tested.
1) Combustion Enhancer Chemical Formula which helps the fuel to vaporize faster during combustion.
2) Emission Toxins passed by through the PCV, now is processed by a Selective Catalyst Processor which is eliminating up to 95% of the Toxins and Reforming Gas to become Recycled Combustion Enhancing fuel
3) Catalytic Injector-Selective Catalyst-Platinum, Rodium, Rhedium, into air mixture
4) Anti Friction Metal Bonding Chemicals to reduce friction -changed 1 year
(Note new technology is 1 application for the life of the engine)
5) ScanGauge E-----monitors Carbon Dioxide------after initiation period 200 miles, the monitoring of Carbon Dioxide should decrease, along with HC and NOx.
6) Tire Sensors for air pressure -----keeping proper tire pressure and regularly servicing the tires at a "Free Service" Tire Discounter, is preferred
7) Once a Year all lubricates for all major assemblies, transmission, trans axle, power steering and crankcase oil, is important until, you have been running all these elements for more than first year, then you can change one every two years. The contaminates which reaches your oil, will not be reaching the oil any longer, those Toxins and By Product of Un Burnt Fuel, will stop because you will be closer and closer to 100% Combustion, no un burnted fuel, burn it all and use it all, leave no Toxins behind.
8) On Horizon, Twin Turbos, to compress the air and mix controlled heat by cooling it down with intercooler. Vaporizing and Compressing Air, to enhance combustion.
If you do all of these installs, You will Double MPG and extend your Range by 150 miles.
Mark G. Cooper
Chief Science Officer
