Old 11-27-2013, 12:07 PM   #49 (permalink)
bikenfool
subey - '99 Subaru Impreza Outback Sport
rav4 - '07 Toyota Rav4
NachtRitter, Sorry if I haven't always been clear. You can call it P&G if you want. Yes, you are increasing the load on the engine on a climb, much like a pulse, but it is still constant speed. I think a correct description of method 2 is constant speed with a short glide at the end (to the top of the hill).
One important point about the difference between method 1 and 2 is that the constraint is constant travel time, so you have to include a flat section, and the DWL method will have to be at a faster speed on the flats to make up the lost time in the climb.
Minor nit: you are misusing the term acceleration, "In physics, acceleration is the rate at which the velocity of a body changes with time" https://en.wikipedia.org/wiki/Acceleration. Of course, you are correct the engine doesn't know the difference.
Originally Posted by NachtRitter View Post
While your speed does not increase as you go up the hill, you are accelerating (the acceleration on the flat ground will result in greater speed, whereas overcoming the force of gravity (which for the engine is indistinguishable from acceleration on the flat ground) will maintain a steady speed on the uphill).
