Old 11-28-2013, 03:08 PM   #6 (permalink)
Palm
Fransyskan - '03 Renault Clio Expression
Welcome, Palm!
I added a pic to your first post... you may be able to add attachments, just not inline images.
That list is a good beginning for your mods.
Thank you!
I'd like to ask a question regarding tire pressure. How much pressure can I safely put in the tires to keep the grip reasonably good? The tires are stubbed winter tires. The weight of the car is 565kg on the front axle and 365kg on the rear without a driver. Renault recommends 29 psi front 28 psi back, although I sense that this is excessively low.
