As far as I can tell, the engine is still very much the same, just modernized a bit. I think mine has a vacuum controlled air intake thermostat, because I later found the disconnected vacuum port. Hopefully that is one problem solved.
I hope the alternator is the same situation on mine, that would be excellent!.
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
