Old 11-28-2013, 10:00 PM   #5 (permalink)
Superfuelgero
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
You also have to consider that the idle speed (and hence DFCO cut off) is dependent upon load (electrical, a/c etc) and temp. If your idle speed with the clutch in is 1500, expect the DFCO to only last until 1750. Its rare that mine will run the minimum idle rpm (which is needed for the 850 cut off). Once past the cut off, it goes back to needing to add fuel not only for the engine, but also the wheels again.
Shooting for 600 miles of range at 65-70 mph out of a vx.
