Old 11-30-2013, 03:33 PM   #1 (permalink)
kach22i
Larger Downforce Near Ground
Vehicle Aerodynamics
How can this be?
I can understand an aircraft landing in ground effect, which squishes and compresses the air between the underside of the wind and or body thereby getting more lift.
However, an inverted wing close to the ground getting more downforce?
How can this be?
Will the air on the underside be accelerated even more when air flow is squished via Venturi effect when in close ground proximity?
