Old 11-30-2013, 08:23 PM   #17 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Originally Posted by basjoos View Post
When idling, the engine runs at normal fuel:air ratios, but it uses so little fuel when idling that the mileage shows 150+ mpg while coasting at any speed over 15mph. Still running the p07-g01 ecu. I run 87 octane with it.
Oh ok. I really have to get a Mpguino hooked up. My afr gauge is the only instrumentation I have. When I dfco it pegs out at 21.9 which is the lean limit on my gauge. If I pop it in neutral on the same hill it will go to 21.5 then slowly get richer and richer the longer it stays in neutral. Sorry hope I'm not thread jacking.
Burn lean and prosper \\ //
