Old 11-30-2013, 10:48 PM   #90 (permalink)
mr220v
Originally Posted by serialk11r View Post
The bore spacing is different between a 1zz and a 1nz, so it wouldn't fit, but I'm going to get a regrind on a spare 1ZZ cam to ~270 from 240 stock and then degree it so the peak is like maybe 7-10 degrees later.
Not NZ, ZR. That would be the current year 1.8L Prius. 2010 on I think. Might be the same spacing and worth looking at. Would make a good intake cam blank if it fit.
