Car has 3.15 gears, lowest numerical in the GT. Not sure on shifting rpm(it's an automatic). Cruising rpm are around 2000 if not a little more, tires are about 27.6" tall
Not sure on tire pressure either. I'll check after I get the car back from the shop however I'm gonna run as high as safely possible(probably around 40)
Edit: Max pressure for my tires is 51 psi
