If you are going the tube frame route, you might look at composite tubing. There is "Pultruded" fiberglass tubing in many shapes, round, square, I-beam, flat, angle, etc., which can be stronger and lighter than steel or aluminum, plus no exotic welding skills are need to join the tubes.
