Old 12-01-2013, 07:32 PM   #18 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
In dfco, the afr gauge would of course be showing lean since the injectors are off and the air fuel ratio would be at ultimate leaness. Idle is at the normal 15:1 ratio, so if you dropped off a lean burn cruise into idle, the afr would drop from the lean burn 21 to the idle 15.
aerocivic.com
