Old 12-01-2013, 09:40 PM   #5 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.42 mpg (US)
The cylinders may be rusty after sitting that long. If you just start it, the rings should scrape the rust out. It will take some life out of the rings and cylinders, but should not be catastrophic.
The cam, however, is a different matter. Cam lobes are THE most lubrication sensitive part in an engine. A dry start with a little rust will wipe out the cam. I suggest removing the rocker arms, checking for any rust, and reassembling with assembly grease before starting the engine.
I also recommend all new belts and hoses before driving it very far. All new light bulbs won't hurt either.
Change oil before starting it. There may be water in the bottom of the oil pan.
Make sure the parking brake works.
