Old 12-03-2013, 09:42 AM   #9 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
However, an inverted wing close to the ground getting more downforce?
How can this be?
Venturi & Bernoulli
If you lower the inverted wing and keep the wing's speed constant, it needs to get rid of the air through a proportionally ever narrower opening.
[the wing's camber is getting ever more important compared to the remaining opening]
This can only happen by increasing the speed of the air even further beyond that of the vehicle, and further lowering its pressure.
This makes the wing more effective at the same vehicle speed.
The Following User Says Thank You to euromodder For This Useful Post:
aerohead (12-04-2013)
