Old 12-03-2013, 12:39 PM   #6 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
Actually, this might be one situation where human->generator->battery/motor->wheels series could be useful. Much easier pedal setup, the generator can be bi-directional for even easier pedal mechanics, and you can top off your battery while stopped, and use a 12v motor for low speed maneuvers with or without the pedals (including reverse). +1 with trolling battery upgrade. It won't be as efficient as mechanical, but the peak exertion should generally be much less if you recharge while stopped.
