I recall the valve cover for my 1990 Honda went up and around the distributor driveshaft. When I figured I knew better than the Honda engineers and left out the sealant in the corners where the gasket turned to go around that, it started leaking at that spot. After that, I always used the sealant where they said to use it. (And it didn't leak from there again.)
-soD
