Originally Posted by euromodder
Maybe whatever air got in, used to go out an easier way before you added the trailer ?
You don't need much air to lift a slab surface.
The rear of the aero cap isn't really all that air tight so what ever air that enters the aero cap shouldn't push the window out like that at all. The only other time that I noticed the rear window moving is when my front top access door was open and the air was being diverted inside the aero cap. Needless to say...the rear window becomes my indicator that my air brakes are on.
I'll take the magnets off and see if the window will still move without the trailer attached.
