I have seen plenty of test that show diesels get better fuel economy with cold air intakes until the ambient air starts to get around freezing.
In my diesel the air is heated to 1100'F adding more heat will waste power compressing the air and forcing the heat through the piston and combustion chamber.
Also adding more heat to the combustion process will increase NOx.
Yes, but your/my 6.5L doesn't have an IAT sensor like my wifes CR does.
Things get all wibbly wobbly when the ECU decides to help the engine warm up by messing with the injection timing/duration.
Simply adding a resistor to the IAT doesn't work as the computer sees the change at the O2 sensor (yes there is one) and tries to compensate.
I disconnected the snorkel on the CR...... and the next day the temp outside went from 40° to 65°.
We have a 2+ hour trip this weekend. Friday evening will be 60s, Sunday will be 45°.
I will let yall know what happens..........
