Old 12-05-2013, 05:49 PM   #33 (permalink)
RedDevil
90 day: 56.53 mpg (US)
Originally Posted by minispeed View Post
That's what I meant by "updating it". Yes the placement of the electric motor is nothing like the earlier systems, but the way in which it uses just 1 electric motor and the fact that there are various gear ratios with a real transmission is.
The change from a traditional CVT belt system to a dual-clutch fixed ratio gearbox is quite radical, and the fact that the electric motor can use the gear shaft not currently used by the ICE as if it were a separate gearbox (in a sense it is) is pure brain candy.
I wish it were an update! I'd have it retrofitted in my Insight at the first chance
