Old 12-06-2013, 09:18 PM   #60 (permalink)
radioranger
radioranger
what we need is a separate throttle body to feed warm air into the air cleaner housing from a heat stove heated by the exhaust, that can be closed for high load operation to allow the factory cold air system to function normally , might not be that tricky. or high tech but would probably help a lot, my escort hates cold weather, at least for FE, also the MTL trans lube although far quieter has cost me about 2 mpg, or could just be the colder weather also. anybody insulating their trans case ?
