So this week-end I bleeded the clutch fluid and now the clutch works like never before, it is clear that I had this problem since I bought the car, but only cold temperatures made me discover it. The car shifts smoothly and no clutch pumping is required.
I will check regularly my fluid reservoir to see if it lowers, but I looked on the lines, the master cylinder and the slave cylinder and there seems to be no leaks.
I had to remove the air filter box to bleed the clutch, so I had the opportunity to see my air filter for the first time has I had previously failed to open my box. It is very dirty! Will change it soon. What do you guys recommend? Honda?
Also, I inflated my winter tires to 45 psi all around and reinstalled my rear fender skirts.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
