A very tidy (but not easier) solution would be to open up the ECU, identify the relevant pins/traces, and solder on some pigtail leads that would then connect directly to the device. All the stock wiring remains intact and reliable. If you're after the easiest installation the vampires are hard to beat, but i also distrust those. I like to solder and shrink-tube all my splicing.
