Originally Posted by t vago
Ooo... you just asked for a novel. Sorry about that.
Really it is a novel, my idea was a bit kind of copy and past just to understand the logic that you use in your code, not all this work we had.
I plan to include a LDR to read the light and pop up a warning indication to turn the car lights when the car start moving, because many times I drive with the light off, which is not good. I also intend to include an audible warning together with an indication.
Another addition I intend to do is a menu with the voltages coming from the O2 sensor and the ECU receives, for use with a HHO system.
The most recent version of the code has been attached to the first post in this thread. In the future, this is where the most recent version will be located.
Sounds good so it is easier to find, instead of having to navigate enters the pages.
Thank you
José Rodrigues
