Old 12-12-2013, 09:38 PM   #31 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by niky View Post
That's assuming buyers are smart enough to refill the water tanks. GM ditched water injection because they weren't.
Unlike urea, where you can have a big enough tank to last till the next oil change, you'll need to refill a water tank often... Unless you have a big reservoir, several times per fuel tank. And it needs to be distilled to keep from clogging nozzles... which will add to cost.
(I love water injection, mind you...)
I agree with the poster above, limp mode would be a very good motivator to add water and "other" water applications have overcome the nozzle clogging issues (mineral deposites) with plain tap water using a combination of being injected through a synthetic and pressure.
Also there is the fact that a proper design could be "cleaned" easily but I digress.
