Originally Posted by nemo
Be sure to check the owners manual. Thought I needed to the same on my car, instead you loosen one bolt and the headlights slide forward.
Thanks - The owners manual says
Originally Posted by Audi
Go to dealer, spend lots of money
However the internet is wise and there are instructions on how to do it. There is one US guy who has
done it (PDF) on a 3.2 Petrol V6 model (mine is the 2.7 V6 TDI) which is quite extensive and I only needed to vary slightly from his plans. The only real changes were the lack of a fuel pipe on the left side of the engine bay (looking in) and the addition of an extra clip to the air filter box.
Originally Posted by Joggernot
Remember to use alcohol to wipe them down before installation and latex gloves when doing the install. I've watched auto store employees take them out of the box while holding the bulb with their fingers to show me they were good. That's when I started wiping them down thoroughly before installation.
Thanks too - I used rubber gloves myself but there isn't a whole lot of need to touch the bulb glass area at all even if I hadn't. The PDF linked above suggests using them due to the voltage used to power the HIDs.
I would suggest the store guys were muppets and ask them to start again with a fresh pair and not touch them this time.
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
