Thread: Diamond Lube
Old 12-15-2013, 04:45 PM   #25 (permalink)
DiamondLube
I approached GM and Ford first, however they refused to consider it. Think replacement parts that are not needed, that is one side effect. Life wear testing at a well known Knife company tested my coating over steel on steel and discovered my coating lasted 30 times longer than their oil and the steel showed no wear, however the machine broke from running too long. You really want to see something that might make sense if you think about it, go to ebay.com and look up ICE SKATE LUBE and I already know an ice skate is not an engine, so don't say it. On the other hand steel that resists wear has to get help from Something. Chris
It's just a high level of skepticism, especially towards unproven claims. Of products being sold to individuals from websites. Instead of to car companies who would probably be buying it by the case.
