I get that, but it takes much more energy to heat up all of the oil (and engine parts) than just the intake air if raising the pre-combustion temperature is the goal you're after. Which I am.
I see the benefit of heating oil. Let nothing distract from that.
Even so, there is a time and place for other systems like heating the intake air. I see my car heat up pretty quickly, but in those few miles it just wastes a lot; those few miles are my target.
The air that gets out passes the catalytic converter first, which only works well when hot enough. Badly burnt cold exhaust gas is a double reason for preheating the intake air.
