As I see it there are two reasons why a cold engine wastes so much fuel.
One is thick oil; added friction so to say.
The other is bad combustion. The system will feed in extra fuel until the oxygen sensor is satisfied, but that means it gets overly rich.
I know about immersion heaters just like oil coolers. They are quite useful, I do not dispute that.They solve the friction part.
Heating the air solves the other part. Air is the medium the combustion process uses. And it works; conventional WAIs are effective, just not in the first few minutes when the engine has no heat to power the WAI,
When the engine is warm the air gets warmed up a bit by the intake manifold and inside the cylinder, and the other wiay round preheated air may lose a bit of heat in a stone cold engine.
Yet, for the sole purpose of heating intake air, I think the eWAI could be more effective than a block heater etc, unless you draw the intake air from around the preheated engine parts.
Best approach would be using block heaters and eWAI combined, solving both issues.
