Thread: Electric WAI
Old 12-16-2013, 01:24 PM   #17 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by RedDevil View Post
The cold season is upon us, nipping any attempt to get good or even average FE in the bud at every cold start.
When it is freezing and I start my car and walk around it I can smell the unburnt fuel from the exhaust. Such a waste, but what to do?
What about electrically heating the intake air?
It needs to be electric; the exhaust manifiold is still cold too at first.
Laid my egg, now shoot
My Subaru 360 which is exhaust heated only (aircooled motor) gets heat in around 90 seconds, so I would lean toward just routing by the cat and manifold first.
Also for instant heat...
You could just preheat the gas tank to 150 degrees F (it works too but is rather dangerous, I did it carefully one time and it has MASSIVE affects in cold weather on warm up time, timing, FE and the whole 9 yards) Had a lot more power off the line as well. As a side note, most fuel systems are rated to 140-160F so you can run a car in a desert safely.
Cheers
Ryan
The Following User Says Thank You to rmay635703 For This Useful Post:
Occasionally6 (01-10-2015)
