Originally Posted by Arragonis
I put Nightbreakers into the Aygo and they were definitely worth the change, I also had some LEDs as sidelights for the same reasons as you but they didn't last long - some seem to go forever (ironically the cheapest on ebay) and others will do well to last 3 months.
Just had to change one headlight in Hermann (£30 bulb ) - I should have done both but as each one requires that side of the engine to be removed I decided the other could wait as it was very cold out.
And yes the weather is cr@p isn't it ?
Am I reading that correctly? Maybe you're just kidding? Do you really have to remove one side of the engine to change the headlight bulb? Nah, can't be, it's just a royal pain with many components in the way, right? I guess if they made common service items easy to get to, who'd take it to the dealer?
