Metro: thanks for the link. That thread got a whole lot longer since I last read through it. And I'll spend some time on it tonight
I have just a vacuum gauge that swings from 0 to 30 so the slightest bit of foot movement reflects quite clearly on the gauge face. Yes, you can lift off every so slightly and see a change on the vacuum gauge with no change on the speedo. If using a boost/vac gauge there might not be enough vac. swing to see the subtle changes.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
